Click for Gulfstream Click for Embraer Click for YachtForums Click for Piper Click for Hawker
Light Jet Thrust Reversers
Discussion in 'Jet Aviation Discussion' started by Mark Fairchild, Nov 13, 2014.
  1. Mark Fairchild
    Mark Fairchild New Member
    Do any of you light jet pilots/owners Premier I, B400, Phenoms, etc) wish you had thrust reversers for contaminated runways, reduced brake/tire wear?
  2. JetForums
    JetForums Publisher/Admin
    I recently spoke with a member of YachtForums who's a principle at an FBO at Kendall-Miami. He's also a distributor of a line of yachts to Central and South America so he flies back & forth regularly. His personal Jet is a Phenom 100. Overall, his ownership experience has been positive, but he's had a few new-jet issues. Regarding short-field landings with the Phenom, the landing speed is around 100 knots and only needs about 250o feet, so you wouldn't need to stand on the brakes at a typical executive. Thrust reversers are nice to have, but you also have the added costs of overhauls, which is probably more expensive then a set of brake pads or tires? Still, if the field is contaminated, the maintenance cost of reversers is easily justified.
