Aero Friedrichshafen Debut For Daher TBM 960
The Daher TBM 960 - Daher Socata's current flagship model has delivered 60 or more examples but it's the first time patrons and customers will get to see the aircraft on display in Europe. Daher's latest example will be on show at the Aero Friedrichshafen in Germany. The example they have on display is painted in the airframers new Sirocco paint scheme as depicted below...
PA-46-based Pipers Can Fly on SAF
Piper is proud to announce that Sustainable Aviation Fuel (SAF) is now available to be utilized on all PA-46 based Piper aircraft. That includes the M600/SLS, M500, and Meridian. SAF is not only FAA approved via SAIB NE-11-56R4, but is available for use in every country that turbine M-Class aircraft operate...
New G400 Experience Tour Launched By Gulfstream
Gulfstream is giving customer the chance to see the G400 cabin mockup first hand to experience the aircraft well before hand. The Gulfstream G400 was announced back in October 2021 to coincide with the NBAA show at the time. Now Gulfstream is affording customers across the United States to envelope themselves in what will be more like the finished cabin of this new model...
Xwing Commences FAA Certification For Autonomous Operations
Xwing's 'Superpilot' autonomous flight control system has formerly commenced Federal Aviation Administration (FAA) certification. The system is installed and intended for the Cessna 208B Grand Caravan and because of this as it is an existing platform they are able to apply for certification as a standard-category airplane. This helps make the process a bit easier rather than having to operated under a special-category. Initially the idea is for autonomous cargo delivery but eventually there will be a conversion towards pilotless passenger flights on this platform...
Regent Unveils Full-scale Mockup Of Viceroy Electric Sea Glider
In a world where electrification of aircraft is becoming more common it isn't just merely eVTOLs that are getting the all-electric designator. More proposals and active testing designs are surfacing for commuter style and even regional aircraft that are all-electric or that combines hydrogen with electric. Here is another name to add to the list, Regent Craft. They are endeavouring to bring an electric sea glider to market by 2025...
Maeve Aerospace Maeve 01 To Fly By 2030s
Another electric airliner has surfaced and this time it is from a Dutch start-up called Maeve Aerospace. The regional airliner itself is called the Maeve 01 and will start-off carrying 44 passengers on journeys approximately 250 nautical miles by 2029...
Brazilian Certification For Garmin Autoland On Cirrus SF-50
A few years after operations commenced with the Garmin Autoland technology following FAA certification in 2020 and EASA certification in 2021, the safety system has now been given the nod by the Brazilian authorities (ANAC) for operations of the SF-50 Vision Jet with the Safe Return Autoland system by Garmin...
Cavorite X5 Wind-Tunnel Testing A Success
Horizon Aircraft have anno0unced that wind-tunnel testing on a 50% scale prototype of their Cavorite X5 eVTOL has been a success. The important tests took place at the world class ACE Climatic Wind-Tunnel facility. Brandon Robinson, CEO of Horizon Aircraft commented: "Aircraft performance exceeded our expectation. We explored forward speeds of up to almost 100 km/h, measuring aerodynamic forces, control authority, and mechanical system function with the wings open at varying fan speeds. We were particularly happy with pitch and roll stability and control throughout the entire transition envelope, as well as the embedded fan performance...
Stratolaunch Latest Flight; A Step Closer To Hypersonic Drop Tests
Last year JF alerted you to what was happening with the Stratolaunch system which involves the world's largest aircraft (by wingspan) called Stratolaunch ROC and its hypersonic test vehicle Talon-A. At the time, the team mounted Talon-A to the specially designed center-line mount but didn't actually drop-test the aircraft from the mount because they needed to understand the aerodynamics of the craft while attached to the Stratolaunch ROC carrying aircraft...
Chapter 11 Bankruptcy Protection Initiated By Virgin Orbit
As a continuation of the news JF published last month regarding the evolving situation around Virgin Orbit, this article serves as a follow-up. You may revert to the previous article here... https://www.jetforums.net/threads/news-virgin-orbit-halts-operations.4583/ . Since then, the company has filed for Chapter 11 Bankruptcy Protection. This all stems from that failed launch attempt that happened at the start of 2023. Nine small satellites were lost when the rocket failed to deploy them in orbit...
Little Rock Dassault Facility Using Continuous SAF For Customer-Bound Aircraft
For the environmentally conscious, Dassault's recent announcement at the end of March regarding its Little Rock Arkansas location will be pleasing. Dassault announced that it is providing Sustainable Aviation Fuel (SAF) for all Falcon customer acceptance and departure flights from the facility. Dassault has now accepted continuous supply of SAF at its completions location in Little Rock...
BAE To Provide Batteries For HS-30
Heart Aerospace is back in the news with an announcement that they are collaborating with BAE Systems for the development of their batteries for the HS-30 hybrid-electric aircraft. As a hybrid-electric aircraft batteries are an essential part of the make-up of the aircraft...
Piper M600/SLS Gets More High Tech From This Spring
From this Spring, the Piper M600/SLS is going to be more high-tech than before thanks to some additions the company is making available to owners of this model. Owners of the newest M600/SLS can look forward to some upgrades to existing G3000 software, first previewed to Piper customers at NBAA-BACE 2022 in Orlando, FL. The updated software includes enhancements to the synthetic vision system, onboard weather radar, navigation, flight planning, checklists, weight and balance calculation capabilities, and stabilized approach monitoring...
Daher To Add EcoPulse Variant To Model LineUp
While Daher Socata has been quietly working on their EcoPulse technology demonstrator to see the feasibility of utilizing hybrid-electric application in future aircraft, there is a definite shift towards adding it as a fifth model to the lineup. Currently Daher builds 4 models, two from their TBM line and two from the Kodiak line. Kodiak 100 Series III and the recently introduced Kodiak 900 as well as the TBM 910 and latest TBM 960...
Jekta Announce First Order For The PHA-ZE 100 Electric Seaplane
Jekta is a a Swiss manufacturer of the electric seaplane called the PHA-ZE 100. A few days ago the airframer announced that it received an order from Gayo Aviation and will take delivery of the aircraft in 19-seat configuration. Gayo Aviation is a global provider of private and specialist aviation services and will optimize the aircraft to support existing and new market opportunities. "We are delighted to be the first customer to sign an LOI with Jekta for this impressive, versatile and comfortable airframe. We want to be among the first to provide our customers with a truly sustainable option to transport their passengers...
Hydrogen Powered Regional Turboprops Sooner Than You Think
A company called Universal Hydrogen is actively working on decarbonization steps and steppimg away from traditional means of fueling the propulsion of regional turboprops like the ATR. To put their work on a testbed and to validate their work, they have been utilizing a Dash 8. That De Havilland Dash 8 hydrogen fuel cell-powered testbed first flew earlier this month and while it was hydrogen-electric, the propeller on one of the engines was a specially made Hartzell prop for the testing missions...
Pangea SY30J Hybrid-Electric By The AirCraft Company
A Wichita, Kansas-based company is pushing ahead with its goal to offer a hybrid-electric, 30-seater regional airliner that it has named the Pangea SY30J. That company is simply called The AirCraft Company and it is a start-up wishing to integrate an Accessible regional carrier...
Final Stretch To Certification For Leonardo AW609 Civil Tilt-Rotor
Although Leonardo does not want to say the exact date that certification of the AW609 Civil Tilt-Rotor aircraft will happen we know for sure that the program is on the final stretch. So much so that both FAA and EASA Staff have flown the test bed aircraft in a run-up to the final Type Inspection Authorization (TIA)...
Vertiia eVTOL By AMSL Aero
Here is an eVTOL from a startup that JF has not covered before. The Vertiia eVTOL is from a startup based in Sydney, Australia. Its design is certainly different than what we typically have been covering on JF. However, does its design differences make it any different to the plethora of eVTOLs in development. The Vertiia will be a hybrid of sorts with it having the ability to fly on battery power alone or hydrogen fuel. Before we delve into the proposed performance figures for the Vertiia eVTOL here is a look at the design of it so far...
eDA40 Eyed For Training Duties With Lufthansa Aviation Training
JF doesn't normally cover Piston aviation as this is a Jet and turboprop Forum. The Diamond DA40 would normally be Piston related but the eDA40 is fully-electric. In the realm of flight training, Diamond Aircraft Austria and Lufthansa Aviation Training (LAT) have signed a Letter of Intent (LOI). The LOI covers an eDA40 purchase intention to supplement the current regular DA40 NG fleet as well as analyses for the use of Sustainable Aviation Fuels (SAF) for the regular fleet. Diamond Aircraft introduced the eDA40 to the market in October 2021...
Page 8 of 96
